Wi FI
- Wi FI
Wi FI
22-03-2015 12:41 PM
I am trying to pair up a couple of devices that are Wi FI enabled, I have managed to do it but the connection is very weak.
The items in question are a Samsung Galaxy Tab and a Transend Car Cam. The signal from the tablet is strong enough so I guess the problem is the car cam even operating the tablet less than a few feet away I get the message cannot find device yet on the odd occasion say one in ten I have been successful and the connection does not drop.
Is there any way I can increase the chances of a more reliable connection ?
We are born into history and history is born into us.
5 REPLIES 5
Re: Wi FI
22-03-2015 2:47 PM
Have you got WiFi Analyser on the tab to check that you are on the best channel?
One thing I've found is that my HTC One has a good robust connection on 5G but my Galaxy Tab 4 is better, more reliable on 2.4G even when both devices are next to each other.
IPad Mini is also working consistently on 5G so the tab has a dubious WiFi connection.
Let's be careful out there !
Re: Wi FI
22-03-2015 3:54 PM
I don't have a WiFi analyser on the tab but thanks for the suggestion I will look into that.
Re: Wi FI
22-03-2015 5:56 PM
inSSIDer used to be king but that one is no longer free.
Re: Wi FI
22-03-2015 6:14 PM
the free versions are available here http://www.techspot.com/downloads/5936-inssider.html
Re: Wi FI
23-03-2015 3:50 AM
"WiFi Analyser" as a decent free wifi app on Android, I use it fairly frequently as every time I change channels on my wifi, someone else seems to move in on the same channel which rather annoys me, hasn't happened recently though, seems they're all staying on channels 1, 6 and 11 here (sky on all three and BT homehubs on 6) and I'm on 8...
