Why does this site object to Adblock and Adblock Plus on Win 7 but not on Win 10
Oldjim
Fixes: 63
http://www.bournemouthecho.co.uk/
I can't see any difference in the settings using Firefox 55.03 32 bit
9 REPLIES 9
Browni
Aspiring Hero
Fixes: 60
Re: Why does this site object to Adblock and Adblock Plus on Win 7 but not on Win 10
It doesn't like Adblock Latitude in Pale Moon X64 running under Windows 10 build 16353.1000 Funny
Boo!Boo!
Oldjim
Fixes: 63
Just to add - and I need to check in the morning - I think that the Win 7 machine may be using the 64 bit version of Firefox
Oldjim
Fixes: 63
Tried 32 bit version and the same result so it must be something to do with how Windows 10 handles it
Oldjim
Fixes: 63
I think I have isolated the problem
Disabling javascript sorts it so I assume it is something to do with how Windows 10 handles javascript as compared to Windows 7
chenks76
All Star
Fixes: 12
using windows 7 64bit here - tested site no complaint about adblock.
using windows 10 64bit at home - tested site no complaint about ablock.
i use uBlock Origin though (which is far superior to either Adblock or Adblock Plus IMO)
Oldjim
Fixes: 63
installed YesScript and blacklisted the site which sorted it
will try Ublock Origin and see how that copes
EDIT
Confirmed that also sorted it so will stick with that for the time being
UPDATE
Checked using YesScript and it blocked the comments being read so not an option
Oldjim
Fixes: 63
Interesting thing from Ublock Origin - following a link from Google Shopping search
chenks76
All Star
Fixes: 12
yes it's doing it's job there.
googleadservices is used for ads and is also used when linking from google shopping links.
just click on temprarily and it'll send you to the original page.
Oldjim
Fixes: 63
better still go to the site and not via Google Shopping Grin
