Why does a txt file take so long to open in Notepad or Wordpad
Oldjim
Resting Legend
Fixes: 63
Occasionally I want to check the routerstats log which is about 67,000 lines long
If I use Notepad or Wordpad it takes ages to fully open so I can see the last few lines but if I use Word or Libre Office (writer or calc) it is much quicker
11 REPLIES 11
twocvbloke
Re: Why does a txt file take so long to open in Notepad or Wordpad
Hang on a sec, I'll go find where I read the reason....
Edit:
Found it, the reason is:
"Microsoft Windows: A collection of 32bit extensions and a graphical shell for a 16bit patch to an 8bit O.S. originally coded for a 4bit microprocessor written by a 2bit company who cant stand 1 bit of competition."
Grin
NotePad++ Is the dog's danglies as far as editors go.
You can get it from here if you want it : http://notepad-plus-plus.org/
avatastic
+1 for np++.
As for the reason, <note|word>pad will be trying to load the entire file at once, Word/Libre Office will step through the file as you scroll through it.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Strat
Fixes: 565
I knew there was something I forgot to reinstall after my rebuild.
Edit: I've just reinstalled it with the latest version and it has an interesting built-in opening page.
VileReynard
Fixes: 20
jeremy@hector:~$ tail ~/'Links/Link to Manuals/Ubuntu_Linux_Bible.pdf'
0046435628 00000 n
0046435738 00000 n
0046435848 00000 n
0046435949 00000 n
0046439495 00000 n
trailer
<</Size 11675>>
startxref
116
%%EOF
Gives an instant response for the last few lines of a 45MByte file. Grin Grin Grin
Fixes: 1,483
prefer UltraEdit myself..
Oldjim
Resting Legend
Fixes: 63
With Notepad ++ it is instantaneous  Grin
Oldjim
Resting Legend
Fixes: 63
I should have used Google to find the answer
Turning Word Wrap off just about fixes it but it still isn't as fast as Notepad ++ although by default it doesn't use Word Wrap
sjptd
I use Notepad++ as general editor of choice.  However, for very large files I find others quicker, such as EditPad Lite, which can also open files too big for Notepad++.  As it doesn't read into main memory searches can be slower.
JayG
Fixes: 6
Quote from: Strat
That's an extra special version just for forum moderators!!  Grin
There is of course Emacs, this is way more than an editor, but can take a bit of getting used to and involves a fair bit of keyboard ballet. Having said that it does come with it's own Psychotherapist and is also supported on Windows.
