Why can't I get to Microsoft Support without logging in
- Why can't I get to Microsoft Support without loggi...
11-02-2015 4:55 PM
Re: Why can't I get to Microsoft Support without logging in
11-02-2015 5:17 PM
That kind of inappropriate redirection could be some kind of malware, but seems a pretty peculiar kind if it is.
11-02-2015 5:18 PM
11-02-2015 5:25 PM
It does it in IE10 and SRware Iron but Firefox takes me to the information. Very strange!
11-02-2015 5:58 PM
Ran Malwarebytes and nothing found
Next step is to remove the updates I just installed
11-02-2015 6:15 PM
11-02-2015 6:44 PM
I just checked on our XP computer and it does the same - goes to login.live and doesn't go back again
The Vista one is way behind on updates so that must be the reason
Will need to investigate further
11-02-2015 7:02 PM
11-02-2015 7:06 PM
11-02-2015 7:10 PM
11-02-2015 7:16 PM
The latest Patch Tuesday batch appeared so I checked a couple.
It did work, but certainly the first one went to the login.live page en route, don't think later ones did.
Something devious going on here methinks.
12-02-2015 8:34 AM
I do on my pc and it always auto logs me in no matter what MS website I visit, when I use my w8 phone it does this same check, I actually read up on it last year and seem to recall it being a "bug feature" caused by the windows live id service, particularly if your already logged in to the live service.
of course if you disable the wlidsvs.eve and wlidsvcm.exe you likely wont be able to use some services like Hotmail ...... me I just let the machine get on with it, of course I also joined the MS experience program on the pc I'm currently having this issue on (the other machine isn't part of it and doesn't do it) so possibly you did the same thing and thus MS checks what you look at when using the system that's part of the program
12-02-2015 10:23 AM
12-02-2015 10:32 AM
if your being annoyed by the login to your Microsoft account page when trying to look stuff up just disable the two wild task running on your pc at boot
12-02-2015 10:37 AM
Neither of those services are running
