Why are the technet participants keeping quite about this
- Why are the technet participants keeping quite abo...
Re: Why are the technet participants keeping quite about this
26-02-2009 6:27 PM
Wipe the hard disc, reformat, re-install , then put all the software back. put the data back
Or is there an easier way these days ?
26-02-2009 6:37 PM
To re-instate the image takes about twenty minutes and can be run from the acronis boot. Data kept on a separate partition will be ok
The only time consuming bit is updating the software that may have installed since the image was taken.
26-02-2009 6:39 PM
Quote from: mal0z Or is there an easier way these days ?
Not really, depends how big your disk is. My preferred method is:
Create new partition (using Partition magic or similar) on existing disk or add new disk.
Do a clean install alongside existing and reinstall required software, change boot defaults to new install.
Copy data files across as required. Once the new install is fully up and running, wipe the old partition and do a clean basic install on it, for emergency/diagnostic use.
26-02-2009 7:23 PM
Quote from: HPsauce I thought Vista SP2 was called Windows 7
Does that make Windows 2000 SP4 Windows XP
01-04-2009 6:22 PM
I've not installed it yet but I suppose I could look at the change log and try it on a test box if someone is interested.
01-04-2009 6:53 PM
Having worked in IT for quite a few years now, I've never got to the stage where I've felt a rebuild would give me anything worth having.
So many people seem to do it with abandon, yet prevention and maintenance seem to be satisfactory.
Have you run through the usual tips and tweaks, such as registry cleans, HDD Defrags and Page File defrags?
Have you checked startup programs, and removed all the unneeded clutter that can so easily build up?
Have you ensured that you are not hitting a hardware bottleneck? (Lots of updates to programs increase the necessary hardware dramatically, so what seemed like enough RAM a few months ago might not be, for example)
Have you ensured physical cleanliness inside your box? (Overheating can cause temporary reduced performance, as well as permanent degradation of components)
Have you disabled all the stuff you don't need? (Extra services, unused hardware etc)
You could be pleasantly surprised how much you can get in exchange for a little maintenance - starting again from scratch only needs to be a real last resort IMO.
01-04-2009 10:10 PM
My PC is 5 years old and on XP SP3 Via Windows 98 and still going well. A bit like trigger's broom though as it's had new Power supply and a replacement mother board
M
02-04-2009 1:06 AM
Quote A bit like trigger's broom though as it's had new Power supply and a replacement mother board
watched that episode the other day
02-04-2009 10:44 AM
I do it every couple of months as i dont have much worth saving on my home PC.
02-04-2009 11:03 AM
Quote from: Oldjim I am running Vista for one reason only - I wanted a 64 bit operating system (not Linux)
Jim, could I ask WHY not Linux?
02-04-2009 12:00 PM
I've just installed Windows 7 Beta 64-bit and it's going very well so far. (had 32-bit on an older system for a while)
A few odd external peripherals are too old for proper drivers but everything "in the box" is fine.
02-04-2009 2:03 PM
Because the software I use won't run on it
Quote from: biker955
02-04-2009 2:43 PM
02-04-2009 3:39 PM
Quote from: biker955 99.9% of the applications I use work in Linux
I don't have 1000 apps on my PC so couldn't get close to that.
In fact I probably have under 100 and use only a handful regularly.
02-04-2009 4:51 PM
Now crossover might be a possibility - I can dual boot linux to try without problems. http://apcmag.com/Content.aspx?id=3649
Something for the dark winter nights perhaps
