Why are the technet participants keeping quite about this
Fixes: 62
Fixes: 247
Re: Why are the technet participants keeping quite about this
Because we're all still using xp or 2003.
If you want to blow up your pc i'm can pass it on. Wink
Posting from a non exploding phone.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
I thought Vista SP2 was called Windows 7  Grin Crazy
(but I bet that Vista SP3 will be, for all practical purpopses)
I wonder if SP2 will make vista work?
Fixes: 62
That's what I want to know - I doubt it  Cool
Fixes: 247
Have to use windows for work, who pay for msdn subscription where sp2 has also appeared.
Im on Vista SP1 here at this very second - and it sort of seems to work - I mean I'm online, using MS Word, Excel and various other programs !  Smiley
But I'm not putting on my home comfuser
Fixes: 62
I am running Vista for one reason only - I wanted a 64 bit operating system (not Linux) and I wouldn't tough XP 64 bit with a bargepole.
Having said that I find the boot up of Vista to a useable state is getting slower and slower but I can't face a reinstall  Sad
pd
Quote from: Santiago
If that were the case they wouldn't be in such a hurry to get Windows 7 out the door.
I am going to have to do Vista re-install on my daughters laptop at the weekend. It is getting slower and slower to boot and shutdown. There are lots of hardware and software issues that I am giving up on trying to sort out, so it's a re-install, It is the only machine we have here running vista, everything else is XP which I find a lot more manageable.
I would put XP on her machine but I don't have a spare copy.
If any of the vista converts out there would like to donate your old and unused copy of XP........ Tongue
What make is the laptop? Lips are sealed  Roll eyes
Acer Aspire 5050
Hmmm not sure about them, don't know how they produce XP CD's.
If it was a Dell any old Dell XP OEM CD would work (desktop or laptop) without any validation issues.... (just need to get the drivers).
Lurker
Quote from: HPsauce
In theory the Dell ones work on any manufacturers kit, but you need to copy the files, and alter the Manufacturer=Dell part to whatever manufacturer made your kit, then burn to a CD ready to install from.
Clearly in order to do such a thing you must take responsibility for ensuring that you are fully compliant with any licensing and regulatory obligations/restrictions.
I have managed to do this with Compaq, Fujitsu Siemens and HP Kit
IANAL
