Why and how or if to go M2 SSD
- Why and how or if to go M2 SSD
04-06-2015 12:31 PM
The present Intel Z97 motherboards support M.2 - PCIe which sounds wonderful except they appear to be connected to the SATA bus - using two SATA lanes to give 10Gb/s so despite the claims they aren't really PCIe connectors unlike the X99 (don't even think about going down that route)
Now it may be obvious - but it isn't to me - but with a standard M.2 SSD there is no difference in performance between it and a standard SSD and the cost is about £90 for 256GB
The alternative is an M.2 PCIe SSD which costs about £130 but looks to be severely bottlenecked by the controller
Which leaves the two questions
Is there any point in going M.2 with a standard SSD given that it takes up two SATA ports
At this time is there any point in putting an M.2 PCIe SSD in a Z97 motherboard given that the improvement in boot time is likely to be minimal
http://www.overclock.net/t/1489684/ssd-interface-comparison-pci-express-vs-sata
Re: Why and how or if to go M2 SSD
04-06-2015 2:51 PM
04-06-2015 3:31 PM
04-06-2015 3:52 PM
Also I have need of all available SATA ports plus the benefit of M.2 over SATA SSD was vague.
Edit: Benchmark attached for the curious....
04-06-2015 4:40 PM
04-06-2015 5:36 PM
Confirms my suspicions about some over hyped technology
05-06-2015 10:21 AM
[Edit] Oops, forgot link: http://www.aria.co.uk/SuperSpecials/Other+products/500GB+Samsung+850+EVO+2.5%22+SATA+6Gbps+32+Layer+...
05-06-2015 10:47 AM
05-06-2015 10:49 AM
05-06-2015 11:03 AM
Quote from: Oldjim out of stock
In the email they sent me it says:
Quote (Stock will be refreshed throughout the day so keep on the lookout)
Once Aria add their delivery charge, this might be just as good - not sure as I've not checked the delivery charges currently.
Quote from: Strat In stock on Amazon £144.50
05-06-2015 11:09 AM
£141.38 with delivery
Amazon £143.98 http://www.amazon.co.uk/Samsung-2-5-Inch-Solid-State-Drive/dp/B00P73B1E4/ref=sr_1_1?ie=UTF8&qid=1433...
05-06-2015 11:20 AM
05-06-2015 11:44 AM
05-06-2015 11:47 AM
My next step is to order the main bits for my rebuild - which will now be a rebuild using my existing case as the other case and power supply just wouldn't hack it
Motherboard GA-Z97-HD3
CPU i5 4690K
Cooler Master Hyper 412S (I was going to get the Scythe Mugen 4 PCGH which is a quieter more efficient cooler but checking clearances I would be forced into very low profile memory)
Then after I find out the clearance under the cooler for the memory - the memory from Crucial
Note that I may be able to locate the fan on the side away from the memory which could be much better from a memory cooling point of view
Then just rebuild using the existing drives (4 sata drives incl. the DVD drive) and GPU
After I have got that working get rid of the Vista partition and dual boot leaving Win 7 64bit
At that point I can decide when to go SSD and the size and rationalise what is stored where as it is a bit of a mess at present (2 x 500GB + 1 x 1TB drives) - note that 256GB will be far more than needed for operating system, programs and data as it will leave over 100GB for other things
05-06-2015 12:22 PM
