Whoops
Tyreal74
Whoops
just checked my account and ive used 60% of my peak usage... oh dear never got that far in a fair few months now.
11gb on peak usage is a bit high for me dont even know what i downloaded..i know i wasted 15gb of bandwidth on 3 corrupt Runes of Magic Installs...
anyone else had a 'Whoops' moment?
James
Re: Whoops
I downloaded the trial version of Windows 9.
Then realisede I need a rewriteable DVD Grin
Fixes: 117
Re: Whoops
Windows 9?  Huh
Will Moderate For Thanks
pierre_pierre
Re: Whoops
you know he has got power and inside info
James
Re: Whoops
Ok, Windows 7.
I guess that was a Whoops moment too Smiley
Re: Whoops
About 3 years ago, I downloaded the MSDN library (4.3Gb) ISO onto an external HD (80Gb at the time I think).
Wondered why the download screwed up just before it finished Angry
The drive had plenty of space.
It had a FAT32 and NTFS partition, and I had tried to save it on the FAT32 one.
Took me ages to realise why, but Google the maximum file size limit on FAT32 and you'll see Grin
Fixes: 117
Re: Whoops
When I was on PAYG I upgraded my Ubuntu box, blew my monthly allowance in a morning  Roll eyes
Re: Whoops
Quote from: Jameseh
I installed it from a USB hard drive :0
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
B.
Re: Whoops
Quote from: Jameseh
That's a pane Grin
pierre_pierre
Re: Whoops
will these do, just downloaded them  (and they are window 9 both of them )
