Which wireless router to get?
frattonpark
Re: Which wireless router to get?
Quote from: James
I'm pretty happy with my Netgear DG834Gv2 (although I think they're on v3 now).  They're really easy to set up and I've always had good reliability.
I've a Netgear DG834Gv2 and its been fantastic. As always its worth rebooting (power on/off) every week as a minimum within any router to keep speeds up.
I'd go for this one
God
I have used the DG834 G / GT / N and all three have worked well. All are really easy to setup.. no need for drivers, all done from your browser.
hulls
Hi
I use a Belkin, and have been generally happy with it.  I thought I had problems, but it eventually turned out to be down to other issues.
Also, when the power supply packed up, and I was asking around for a replacement, a very helpful assistent is Staples pointed out that Belkin guarentee the power supplies for life.  I contacted the company and got a free replacement within a few days.  How about that for service? Shocked
