Which router?
- Which router?
Which router?
08-06-2015 10:38 AM
I want to buy a router for several reasons. I want to be able to use RouterStats for a start.
So which router should I buy? Any opinions anyone?
6 REPLIES 6
Re: Which router?
08-06-2015 11:15 AM
Would that be for ADSL or Fibre?
Geoff,
York.
York.
Re: Which router?
08-06-2015 12:50 PM
Sorry. ADSL. No fibre yet at this end of the street in Central London.. sigh.
Re: Which router?
09-06-2015 8:58 AM
Quote from: BurntToast So which router should I buy? Any opinions anyone?
the best one you can afford.
Re: Which router?
09-06-2015 5:09 PM
Quote from: BurntToast Sorry. ADSL. No fibre yet at this end of the street in Central London.. sigh.
Might be worth looking at some of the dual purpose devices that can work on both ADSL & fibre, be a shame to buy a decent / high spec router then find its useless if / when you upgrade to a fibre service in the future.
Re: Which router?
10-06-2015 10:08 PM
Certain parts of central London will not get fibre for the foreseeable future....
Re: Which router?
12-06-2015 6:23 PM
I lived at the other end of a not very long street and they put a cabinet outside my door. This end of the street doesn't connect to it or any other fibre cabinet. A bit weird but I don't suppose it matters as long as an ADSL connection works most of the time.
