Which router?
BurntToast
Which router?
I want to buy a router for several reasons.  I want to be able to use RouterStats for a start.
So which router should I buy?  Any opinions anyone?
6 REPLIES 6
NedLudd
Re: Which router?
Would that be for ADSL or Fibre?
Geoff,
York.
BurntToast
Re: Which router?
Sorry.  ADSL.  No fibre yet at this end of the street in Central London.. sigh.
chenks76
All Star
Fixes: 12
Re: Which router?
Quote from: BurntToast
the best one you can afford.
PowerLee
Re: Which router?
Might be worth looking at some of the dual purpose devices that can work on both ADSL & fibre, be a shame to buy a decent / high spec router then find its useless if / when you upgrade to a fibre service in the future.
Champnet
Aspiring Hero
Fixes: 12
Re: Which router?
Certain parts of central London will not get fibre for the foreseeable future....
BurntToast
Re: Which router?
I lived at the other end of a not very long street and they put a cabinet outside my door.  This end of the street doesn't connect to it or any other fibre cabinet.  A bit weird but I don't suppose it matters as long as an ADSL connection works most of the time.
