Which one should i get ?
- Which one should i get ?
24-10-2012 6:56 PM
http://www.amazon.co.uk/gp/product/B003FS40KU/ref=s9_simh_gw_p147_d0_i3?pf_rd_m=A3P5ROKL5A1OLE&pf_rd...
http://www.amazon.co.uk/gp/product/B00380X5HE/ref=s9_simh_gw_p147_d0_i4?pf_rd_m=A3P5ROKL5A1OLE&pf_rd...
I need to try another router, but as im not clued up on routers i need to ask what you peeps think, ideally i want to spend as little as possible.
Needs to be ADSL Wireless modem+router
Re: Which one should i get ?
24-10-2012 7:02 PM
24-10-2012 7:05 PM
24-10-2012 11:03 PM
http://www.amazon.co.uk/Belkin-Wireless-Adsl-Modem-Router/dp/B000IG94TE/ref=sr_1_4?s=computers&ie=UT...
http://www.amazon.co.uk/Belkin-802-11g-Built--Wireless-Enclosure/dp/B001IL9P7Y/ref=sr_1_9?s=computer...
http://www.amazon.co.uk/Belkin-802-11g-Wireless-F5D7632uk4-F5D7050uk/dp/B0007DGWZC/ref=sr_1_12?s=com...
Bear in mind you will probably get what you pay for but if it is only to try something out and you don't want to spend much they may be ideal
24-10-2012 11:09 PM
Anyway apart from that, it's been a good router. It even has usb for a usb drive to be shared on the network. Built in FTP server to access those files from the outside world, all the usual stuff..
Only thing it doesn't have are statistics for things like line attentuation and all that tech stuff that a tech department might want to know if you have problems. At £95 (serious money for a router) I'd expect to be able to see those!
24-10-2012 11:56 PM
His never let me down before, he swears by netgear or draytek he said draytek are the best in his views, altho they are too much dosh for what i want.
Anyways i went for netgear again hopefully this will sort my issues.
25-10-2012 11:11 PM
26-10-2012 9:03 AM
26-10-2012 10:32 AM
Go for the one that doesn't have a silly name and stupid spelling.
26-10-2012 11:30 AM
26-10-2012 4:44 PM
27-10-2012 7:38 PM
30-10-2012 7:47 AM
Quote from: gleneagles Did PN not supply you with a free router ?
It's not free, it's £4.99 P&P and a £40, 12 month deferred contract.
30-10-2012 3:24 PM
True you pay £4.99 for P & P but how many adverts do you see where something is advertised as Free but a charge is added for P & P.
30-10-2012 3:39 PM
It should be advertised as free - but only if you drive up to Sheffield.
