Which is the best free firewall?
- Which is the best free firewall?
- « Previous
- Next »
Re: Which is the best free firewall?
10-03-2008 10:44 AM
Quote from: scootie
Quote from: greyposter Vista and Zonealarm are working for me and so is 'Plusnet'.
what version vista u runing and what anti virus u running along side zone alarm. all thoe i dont think it was a confilct with avg as i uninstalled avg but zone alarm still froze up.
comodo does the job fine. but has any one used both zone and comodo and tell me if it would be worth trying to solve the zone alarm problem i got?
Never heard of Comodo, but I am surprised that you can't get ZA to work with Vista.
10-03-2008 2:27 PM
looked good simply controls unfortonetly installed it just before midnight when it came to start utorrent for free usage. za gave me a pop up to let me get utorrent on the net but people were handshaking but then droping connection and got nothing downloaded so after half hour reinstalled comodo and everything was fine might give za another chance soon.
any one know what za settings i sould of set to let p2p work?
13-03-2008 11:42 PM
Although I am happy that my router is blocking most unwanted inbound connections, Zone Alarm is very good at stopping uncontrolled virus downloads. Once in a while when I download a virus from a site (Latest being xrun.exe) Zone Alarm stops it connecting to the internet to get all its friends. Without Zone Alarm you can end up with loads of the evil buggers to clean up by the time AVG alerts you!
03-07-2008 11:18 PM
ZA is quite a way down the list.
I went for Comodo and have been running it for some time with no problems on Vista.
13-07-2008 9:02 AM
13-07-2008 9:40 AM
19-07-2008 4:15 PM
Have been using Comodo for months now on a number of PC's without any problems. I did try the latest one and didn't like it so reverted to a previous version (2.4.18.184).
Incidentally if you uninstall ZA make 'sure' it's turned off first. The uninstall will proceed ok BUT if you want to re-install later you may have problems as ZA leaves some crud behind and that confuses the new install - been there - done that - had the headaches to prove
Good luck,
21-07-2008 7:33 PM
Kaspersky is probably the best at the moment.
Edit: My description of MS firewall & AV was censored! All I said was c**p, but it looks much better with 'censored' plastered across like that.
21-07-2008 9:06 PM
Quote from: realafrica You get what you pay for. Free firewalls are never as good as the ones you pay a few quid for. Microsoft's Firewall and antivirus are [Censored] and should never be used. If you really want protection you should make sure they stay switched off and pay a little for a decent security package.
Kaspersy is probably the best at the moment.
Read my link a few posts back, I think you'll find the free firewalls are actually better then the paid ones, and not by a small margin either
21-07-2008 9:33 PM
21-07-2008 10:02 PM
- « Previous
- Next »
