Which is the best anti virus prog for mac
- Which is the best anti virus prog for mac
02-08-2014 7:45 PM
Re: Which is the best anti virus prog for mac
03-08-2014 3:52 AM
Although I use ClamXav as an extra on top of Sophos, scanning downloads and emails 'n' such.
12-08-2014 11:00 AM
12-08-2014 3:26 PM
For that being your first post here, it's not a good start.
Other than that, welcome to the community.
12-08-2014 5:40 PM
Again my advice unless dual booting is to leave it alone.
12-08-2014 8:24 PM
Anyway in this day and age of large amounts of RAM & HDD space and fast processors, surely adding a little bit of extra protection for minimal performance impact is a no brainer. I can't really understand your point of having nothing, unless your point was that it gave a false sense of being protected but that's not what you're saying.
12-08-2014 11:58 PM
Quote from: RPMozley Sophos free Mac version is ok. http://www.sophos.com/en-us/products/free-tools/sophos-antivirus-for-mac-home-edition.aspx
That is exactly what I do on my iMacs
And I agree totally with all your other comments.
Your experience in all things Apple is much appreciated.
13-08-2014 7:43 PM
Also got a warning last year from my AV about badware when I downloaded something from download.com (CNET is it? Avoid that place!). So always useful to have.
Is it possible you may pass on a virus to a friend if you share docs even though it doesn't effect you?
13-08-2014 7:49 PM
Not sure if they are actual threats, but better safe than sorry.
13-08-2014 10:30 PM
Quote from: IanSn Caught a nasty on an 8600 back in the day, so it was possible even then. Forget what was though.
Probably one of those Microsoft Office Macro viruses? Not really much of a threat seeing as it was obviously only activated if you had Office installed, it didn't do anything with other software packages.
Quote from: IanSn Is it possible you may pass on a virus to a friend if you share docs even though it doesn't effect you?
Yes that is a possibility, so check your docs before sharing or you may lose a friend!
@ PlusComUK
I've seen a few false positives with ClamXav with regards to the phishing email checking but not in a long while. I might have disabled it though, as it's heuristics were just too over sensitive and didn't help track down which particular email was the problem due to the way Thunderbird stores the emails.
13-08-2014 10:45 PM
edit -
Didn't use AV in those days, only found out about the bug because the program went nutty and contacted authors.
13-08-2014 10:58 PM
13-08-2014 11:08 PM
@ PlusComUK
I only use Apple Mail, and ClamXav identifies individual emails, but you probably already know that !
14-08-2014 1:11 AM
Yep, think it was only that program. Some prankster, I guess, there were only a couple of them worked on that as I recall.
&@PlusComUK
Is Thunderbird one of those that are really messy with the files it saves? Think Outlook Express used to do that? Or was it AOL mail?...
If TB does that as well, I've gone off it a little bit...
14-08-2014 11:05 PM
All in all though, scanning for phishing type emails is rarely required as they are quite obvious. Just some simple knowledge is required.
