Which free distro
- Re: Which free distro
Which free distro
26-05-2010 4:00 PM
Toying with the idea of loading linux as it will just be used for surfing.
spec is
1gb ram
Intel atom processor
160gb hard drive
Any recommendations as to which free distro would be best
thanks
26-05-2010 4:52 PM
Use those that can run (sluggishly) from CD "a live disk" - these won't touch your disk.
Ubuntu and Mint seem popular.
26-05-2010 5:48 PM
What size screen is it? If it is 7-9" I would recommend a nettop version, or the standard with the NBR remix added, if it is a 10" or above then OOB will be fine.
The NBR gives you a large onscreen menu and maximises the apps as they run. Also look at easypeasy (a Ubuntu remix for netbooks)
If you are loading from a M$ OS then download the unetbootin app to create a bootable USB to work from if it doesn't have a cd drive (which I think is the case?) 1Gb or larger required,
26-05-2010 6:45 PM
I've had an Aspire One with similar spec ( 9" screen ) running Ubuntu NBR for about 9 months now. As HB says NBR is better on the small screen. I started off with 9.04 but recently upgraded to 10.04. Performance is excellent , I use mine when away from home for browsing, email etc.
USB 3g dongle support is much improved in 10.04 but there was an issue with Skype and sound.
Shout up if you need more info.
26-05-2010 7:56 PM
Am downloading NBR later
26-05-2010 8:01 PM
26-05-2010 8:07 PM
any going to format the drive and blow windows off completely
26-05-2010 8:31 PM
My AA1 came with Linpus installed but I rapidly decided that Ubuntu NBR was much better.
When you get it all installed you might want to read this http://ubuntuforums.org/showthread.php?t=1424043. the acerhdf fan control module is now part of the standard kernel but you do need to put specify some modprobe parameters for it to work effectively. Its worth it though, the AA1 fan can be a little noisy!.
I ended up having to set up about 8 of these AA1's with UNR in the office, I found an offer on the Linpus one with 120Gb disc and 1Gb memory for £150. When people in the office saw mine with UNR on it many of them went and bought them, course they all wanted me to set them up with UNR instead of Linpus
IIRC I also updated the bios on the machines to the most recent ( 3310 I think! ) before I started.
27-05-2010 3:49 PM
Downloaded any tried them all and have plumped for Mint.
Just seem to like it better than the others.
Running like a dream - fast and reliable
thanks for the advice
