Which email system?
fotobits
Which email system?
At the same time as switching from  e-e to plusnet, I have replaced my mobile.
So far, I have been unable to install an email system on the new mobile .  Any recommendations?
The system I used on my first mobile was recommended by a PlusNet advisor about 3-years ago on this site but is no longer supported by the latest Android.
Regards
7 REPLIES 7
Mav
Fixes: 515
Re: Which email system?
Some here use K-9 Mail, myself included.
Forum Moderator and Customer
fotobits
Thank you MAV.  K-9 is what I've been using so far!   But I'm blessed if I can get it to install in a recognisable or workable form.
When I attempt to install it, it does indicate that it was designed for an earlier Android.
Can't think what I'm doing wrong.
Regards
Mav
Fixes: 515
It's working fine on my Samsung A5 with Android 7.0.
Fixes: 396
... and here on Android 5.x and 6.x
paul_blitz
When I moved form a company iPhone to an Android phone, I too needed to find a good email client.
I tried K9 and found it just didn't work the way I expected it to (eg swipe email left to delete it).
I tried BlueMail, which works the way I expected, but support for multiple email accounts isn't simple to use.
So, I'm currently set up with BlueMail still for one of my accounts, and Outlook for the other two. Now I'm used to Outlook, I need to move that other email over to it.
fotobits
Thank you all very much for the comments and experiences.  I've tried a number of offerings from Play Store, however, not happy with what I saw.
Had another go installing K-9, this time with complete success....Don't know why and transfer of Contacts achieved as well!
Thank you all.....
Regards....Noel
Mav
Fixes: 515
@fotobits
Glad you got it sorted.
