Which One
- Re: Which One
Which One
18-04-2013 5:26 PM
Re: Which One
18-04-2013 5:34 PM
Re: Which One
18-04-2013 5:38 PM
As Oldjim says, you can use both.
I would also recommend SpyBot S&D v1.6.2 as well.
Forum Moderator and Customer
Re: Which One
18-04-2013 5:48 PM
Re: Which One
18-04-2013 5:56 PM
I would recommend Microsoft Security Essentials as it's free and does the job well without hogging resources.
If you're using windows 8 then MSE is otherwise known as Windows Defender.
Re: Which One
18-04-2013 6:05 PM
I do use Speccy (from Piriform) though give good Hardware analysis
