Which Linux
- Re: Which Linux
Which Linux
03-11-2009 1:17 PM
I'm soon to be playing with Samba, and hopfully setting up a Domain Controler using it for use by a Church. What favour of linux do you recommend for use in more of a server environment?
Phil
Re: Which Linux
03-11-2009 1:37 PM
Re: Which Linux
03-11-2009 2:25 PM
What hardware are you planing on using it on also plays an issue, do you want/need a GDM or can you hack the terminal/use webmin?
Re: Which Linux
03-11-2009 2:37 PM
Phil
Re: Which Linux
04-11-2009 1:43 PM
I used to use it as a firewall/print server/mail server for my small network running on a Via 1Ghz 384Mb. No GDM but a nice web based Gui.
Re: Which Linux
04-11-2009 1:54 PM
Phil
Re: Which Linux
04-11-2009 3:53 PM
If you need to be more bleeding edge, Fedora Core should be the ticket.
I'm suggesting it mainly because you're already used to RHEL, so everything should be familiar
B.
Re: Which Linux
04-11-2009 9:25 PM
Re: Which Linux
05-11-2009 12:05 AM
Better than spending a fortune on Microsoft Windows Server
Sorry, couldn't help that.
I thought Dell used to have a tie-up with Cannonical (Ubuntu) but I think that might not have related to the PowerEdge Server range, if they did supply these machines with Ubuntu then it would be a sensible choice as Dell themselves might have some support.
I would definitely agree with using an 'older' long term support distribution rather than latest 'state of the art' version, especially on 'not quite new' hardware.
Re: Which Linux
05-11-2009 8:38 AM
Phil
Re: Which Linux
08-11-2009 3:08 PM
Quote from: biker955 Another one to have a look at is Clark Connect, it is more of a GP server, email/shared folders/printer sharing OOB. Ver 5 was just released (a couple of months ago) and is based on CenOs 5.
I'm using ClarkConnect 4.3 and find it to be excellent - easy to use and well supported on the forum.
It has changed it's name recently and is now known as ClearOS.
