Which Linux?
- Which Linux?
Which Linux?
29-12-2016 6:03 PM
My brother brought home a rather old PC from work that used to be used for testing lifts. It is running Vista but by the specs I would say it must be around 8 years old at least. It starts up OK but, unfortunately, no-one can supply a password.
Considering it is for my sister-in-law to use just for emails, web browsing and downloading and storing photos from her camera and she has never really used a Windows PC I have suggested to my brother that I may as well install a version of Linux rather than spend money on a Windows disc and key.
I have used Linux myself a few times but usually to access a drive that Windows wouldn't see. So my questions are which would be the best version out there to use that will offer the most simplistic set up and be easiest for my SIL to get to grips with? Does it come pre-installed for downloading photos and setting up an email client.
Are there any potential issues I should look out for?
Appreciate any advice you can offer.
Thanks.
Forum Moderator and Customer
Re: Which Linux?
29-12-2016 6:26 PM
Personally I use cantos 7, it's easy to use at install you can say it's a desktop pc and you get mail client, web browser etc installed. It's easy to put other things like gimp for picture editing
You can also get a "live ISO" that you put on a USB drive and just boot from that, so you can test with no install to check it out.
Only thing to watch out for would be any driver incompatibilities.
For a small amount of cash I'd suggest getting a cheap 128gb ssd and ditch the current drive if it's that old. £50 gets you something like https://www.overclockers.co.uk/kingston-120gb-ssdnow-v300-drive-sata-6gb-s-3-2.5-7mm-height-solid-st... and it will be much faster. (May need a adapter if pc isn't data one).
If you are on unlimited download http://isoredirect.centos.org/centos/7/isos/x86_64/CentOS-7-x86_64-Everything-1611.iso and on a pc use something like http://www.isotousb.com/ to make bootable USB drive.
On the pc you may need to go into the bios to let it boot from USB too, failing that write the ISO to a DVD and boot from that!
Let us know if you have any problems.
Re: Which Linux?
29-12-2016 7:15 PM
I put Ubuntu 16.04.1 LTS on a laptop which originally had Windows XP.
I downloaded a suitable ISO and burnt it to DVD on my main desktop computer, Installation on the laptop from that DVD was straightforward. One can afford to do a trial run, then start again if desired eg want to change partition sizes. Creating a separate partition for /home (user files) keeps them separate from the operating system.
It comes with Thunderbird for email and Firefox for browsing. For photo manipulation GIMP can be installed easily as a package though I haven't tried that.
Re: Which Linux?
29-12-2016 7:42 PM
Thanks for the replies.
I have seen Ubuntu mentioned on these forums many times so will probably go for that. Earlier this year I bought a 240GB SSD to replace the 60GB SSD in my PC so may be a good idea to fit the unwanted 60GB into the Ubuntu machine to load the OS on and use the existing HDD for data.
Can Ubuntu be installed from USB as that may be the easiest option?
Re: Which Linux?
on 29-12-2016 7:57 PM - last edited on 29-12-2016 8:01 PM by Mav
Ubuntu is good too.
Have a look at https://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
Links to download instruction and USB install instructions.
Moderator's note by Mike (Mav): Link fixed.
Re: Which Linux?
29-12-2016 8:02 PM
Thanks for the link. Will have a look shortly.
Re: Which Linux?
29-12-2016 8:18 PM
Given the age of the machine you might be wise to choose a more lightweight desktop environment than Ubuntu's default Unity; if the machine struggles with Unity I'd suggest you try Ubuntu (or Mint) MATE.
Re: Which Linux?
29-12-2016 8:20 PM
Another option for the HDD is to use it to back up user data. A major feature of Linux is that you don't have to ask permission from Microsoft if you want to do something that suits you rather that what they allow you to have.
Re: Which Linux?
29-12-2016 8:49 PM - edited 29-12-2016 8:52 PM
It's the the best way imo, it also gives you the option of running live with persistence
Burning DVDs is just inconvenient and archaic at this point. Especially with many modern machines not having optical drives
I would recommend using Etcher to burn the ISO, it's clean, simple and cross platform
Re: Which Linux?
30-12-2016 12:42 AM
The most similar looking to Windows is probably Mint - but it gives you lots of choice in configuring a version to suit your preferences.
Ubuntu is easy to install, either from DVD or USB like all Linuxes but comes with a horrible desktop. (In my personal opinion).
Don't choose a version that is not widely used as you will find it difficult to get support.
Re: Which Linux?
30-12-2016 8:59 AM
I'm not suggesting that Linux is not a better option than Vista but it would probably be possible to remove the Windows password if you wished.
Re: Which Linux?
30-12-2016 9:39 AM
Personally I have been using Mint for over 8 years now. www.linuxmint.com get the Mate version of 18.1.
Re: Which Linux?
30-12-2016 2:50 PM
Vista will continue to receive updates until 11 April 2017.
Re: Which Linux?
31-12-2016 10:05 AM
Re: Which Linux?
31-12-2016 11:46 AM
You can trial Linux (at a slow speed) by booting from DVD or USB, without affecting your hard disk.
So you can use your 4 months usefully...
