Which DirectX have I Got?
- Re: Which DirextX have I Got
22-12-2009 2:24 AM
Quote Display adapter type ATI Radeon HD 4800 Series
Total available graphics memory 1919 MB
Dedicated graphics memory 512 MB
Dedicated system memory 0 MB
Shared system memory 1407 MB
Display adapter driver version 8.681.0.0
Primary monitor resolution 1920x1200
DirectX version DirectX 10
Running the DirectX Diagnostic tool I get:
Quote Time of this report: 12/22/2009, 02:17:10
Machine name: MIKESPC
Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 06/29/09 20:07:07 Ver: 08.00.15
Processor: AMD Phenom(tm) II X4 940 Processor (4 CPUs), ~3.0GHz
Memory: 4096MB RAM
Available OS Memory: 3328MB RAM
Page File: 2477MB used, 4174MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
So which is correct.. DirectX 10 or DirectX 11?
Forum Moderator and Customer
22-12-2009 8:01 AM
Though wonder if your card isn't DX11 compatible so you have DX11 drivers but reports as DX10 as it can't use all the features?
22-12-2009 10:29 AM
However as part of trying to find it I ran the performance check with the attached result.
Note I have an E6750 Core2duo processor, 8800GT graphics and 4GB ram - the reason for the poor memory report appears to be this from the Task Manager
Physical Memory
Total 4094
Cached 2633
Available 2965
Free 387
So the fact that Windows has cached a load of memory means I haven't enough
Also the boot partition has 63.3GB free out of 97.6GB
A reboot fixed everything - it looks as though using sleep mode continuously messes up the system performance rather badly
22-12-2009 10:32 AM
22-12-2009 10:43 AM
22-12-2009 10:50 AM
22-12-2009 11:26 AM
