Where`s my Linux Mint 14 gone?
shutter
Fixes: 65
OK... a rhetorical question.... but....
I have a HDD that I am messing about with Linux Mint. and it is in a caddy connected to my lapotp via USB cable....
when I go to "my computer"... the hdd does not show as an additional drive... yet the drive is in use, the light is flashing and the disc is revolving... I know it is there, cos I have just been working on it,.... so is Windows so high and mighty it does not recognize Linux ?
22 REPLIES 22
HairyMcbiker
All Star
Fixes: 21
Re: Where`s my Linux Mint 14 gone?
It will probably be in your drive manager (or disk manager or WHY) as an UNKNOWN DISK.
shutter
Fixes: 65
Nope... Windows does not recognise the drive as being there ! ...  (see my original description....  Cheesy  )
DaveyH
Champion
Fixes: 12
Windows doesn't recognise EXT 2/3/4 file systems.
There are drivers you can install though, if I recall.
HairyMcbiker
All Star
Fixes: 21
If it isn't seeing the WHOLE drive, then check the usb devices and see if it even sees the usb to HDD adapter.
shutter
Fixes: 65
If I were to put windows on the same hdd in the same caddy and the same usb plug hole, it would be recognised as Drive E:/    but because it onyl has Linux on it,  windows doesn`t even see the drive !...
HairyMcbiker
All Star
Fixes: 21
Now that is spooky. There is no reason it shouldn't "see" the drive, even if it has a "foreign" OS on it.
w23
Fixes: 4
But it will only assign a drive letter to a drive or partition containing a filesystem that it is able to recognise (FATx, NTFS)
Call me 'w23'
HairyMcbiker
All Star
Fixes: 21
Yes but shutter is saying it doesn't appear in the disk manager as a drive at all, it should appear as unknown fs.
PeeGee
HB: I'm not sure that is the case - that has not been stated explicitly and all references are "explorer like"; eg Drive E:, not disk manager.
shutter: presumably it appears as a bootable drive in the BIOS list, as you are "messing about with Linux Mint"?
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
shutter
Fixes: 65
Yes, I am "messing about" with Linux Mint.. and have some "spare HDD`s" that I load up with various versions and then I remove the HDD from the laptop and boot into the Linux Mint HDD in the caddy... however, If I have the Windows HDD in the laptop, and a Linux Mint ( or any other linux version) on the Caddy/USB it does not show as a drive at all on the  "my computer" list of drives. If I were to put a windows version on the caddy with the windows in the laptop, then  it would show as an extra drive...as does a USB memory stick....
Haven`t looked in the bios listing....
Except to make the order of boot ups - anything before the HDD !
It is not critical... just "weird" or as HB puts it "spooky"... and I wondered if any of the experts could answer the question ! .
ejs
Aspiring Hero
Fixes: 25
It's not weird nor spooky, and your question has already been answered more than once!
Windows doesn't assign a drive letter to a filesystem (Linux ext4) it can't read. So a drive with the contents of a Linux installation won't appear in "My Computer".
Run diskmgmt.msc (or right click My Computer, choose Manage, then open Disk Management).
shutter
Fixes: 65
Yes it does show on the Disk Management  ....
HairyMcbiker
All Star
Fixes: 21
HMM See reply #1 & 2  Angry
shutter
Fixes: 65
Don`t understand the  Angry ... as far as I am concerned, if it does not show up as a Drive on my computer... then it is not showing.... and I can`t use it....
just because some part of windows system does see it, does not make it usable, and therefore my original description and question is not oblique. unlike some of the answers...  Cheesy
