Where is the address book?
- Where is the address book?
04-10-2013 8:35 PM
I am trying to transfer my address book on Thunderbird on a recently removed HDD, to a new install on another HDD...
I know the file is .ldif However, after putting that in the "search box" ( above the START button)... it does not produce a result.... ( well it did, but that was an old old old version that I saved into a folder a long time ago )... I want to find the latest copy of the address book file, to make sure I don`t lose recent contact addresses...
I vaguely remember something about Mozilla and Roaming.... but can`t seem to find it in there either... ( just downloaded and installed a new copy of Thunderbird hence the need )...
Any help appreciated.....
(Old thunderbird is in a caddy as Drive E:/ and running windows vista home premium )
thanks
thanks
5 REPLIES 5
Re: Where is the address book?
04-10-2013 9:04 PM
you would probably need to change the folder view options to see hidden and system files
04-10-2013 9:11 PM
I had already done that, ! but just double checked to make sure ! ...
04-10-2013 9:39 PM
I assume you tried this http://forums.mozillazine.org/viewtopic.php?f=39&t=239100
04-10-2013 10:11 PM
No, But,.... while you were kindly researching for me.... I have found a way of doing it. !....
Go to Address book on Thunderbird....
Click on the Personal Address book
Select/highlight all the addresses
Click on Tools
Click on Export ( this opens a "save" dialogue) Enter a name and "save" it to Documents as .LDIF file
Click on Collected Addresses
Click on Tools
Click on Export ( open the "save" dialogue) Enter a name and "save it to Documents as .LDIF file
Now... Copy the two .LDIF files over to the new hdd and then.. (using the Import command on Tools ) . on the new Thunderbird all you need to do is to locate the saved copies and paste them as new address books.... You can then copy them to the Proper address locations, and delete the "donor" folder as it will be empty !...
Thanks for your efforts, as usual, Jim.... much appreciate it.
Click on Tools
Click on Tools
04-10-2013 11:25 PM
I find Mozbackup a great utility for backing up FF and TB
http://mozbackup.jasnapaka.com/
Regards
Mike
Quote It allows you to backup and restore bookmarks, mail, contacts, history, extensions, passwords, cache etc. It's an easy way to do Firefox backup, Thunderbird backup
Regards
Mike
