Where has Character Map gone?
birdman
At some stage or another, Character Map appears to have vanished from my XP system, so I can't now use symbols such as the one for degrees. Any ideas anyone? Huh
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Where has Character Map gone?
Try going to start > run and then type in 'charmap' without the 's
It should load.
 Chris Parr
 Plusnet Staff
birdman
Thanks for that Chris. Did what you suggested but windows couldn't find it. So, I ran a search for charmap and it came up with charmap.exe which loads it. Problem solved. Smiley
Start>accessories>system tools>character map
birdman
Yes artmo, that's where it should have been, but it had diappeared from there and couldn't be found elsewhere. Having found the exe file in the system32 dll cache from a search, I was able to drag and drop it into System Tools and it now loads fine. Thanks for your response.
Lurker
ALT+0176 = °
Much shorter than clicking on stuff Smiley
ALT248 works as well °
Denzil
... which is fine if you can remember them Smiley
pimpernel
Write them down!
Rich
Full list here...
http://www.tedmontgomery.com/tutorial/altchrc.html
... might be worth printing?
