Where did this come from in Internet Explorer when right clicking
Oldjim
Fixes: 63
The last couple of items
5 REPLIES 5
Gel
Aspiring Champion
Fixes: 28
Re: Where did this come from in Internet Explorer when right clicking
Will have been on some s/ware you installed as one of the options; I always refuse them.
My context IE11 menu as attached.
FreddieFlint
Try running Malwarebytes, get rid of them unless you, and it sounds like you didn't, DLed them deliberately
Casey
Oldjim
Fixes: 63
I have sorted it
It would appear that this is something added by ieSpell (and possibly others) which I uninstalled a long time ago
To get rid of them I actually had to edit the registry where they were under menuext
Just to add - although I did it myself one of the links by @Casey also showed how to do it
Gel
Aspiring Champion
Fixes: 28
I always find it best to remove any s/ware using free prog "Advanced Uninstaller"; it scans registry for all those odd places that s/ware may have left traces.
