Where did this come from in Internet Explorer when right clicking
Fixes: 60
The last couple of items
Gel
Seasoned Pro
Fixes: 12
Re: Where did this come from in Internet Explorer when right clicking
Will have been on some s/ware you installed as one of the options; I always refuse them.
My context IE11 menu as attached.
FreddieFlint
Try running Malwarebytes, get rid of them unless you, and it sounds like you didn't, DLed them deliberately
Casey
Fixes: 60
I have sorted it
It would appear that this is something added by ieSpell (and possibly others) which I uninstalled a long time ago
To get rid of them I actually had to edit the registry where they were under menuext
Just to add - although I did it myself one of the links by @Casey also showed how to do it
Gel
Seasoned Pro
Fixes: 12
I always find it best to remove any s/ware using free prog "Advanced Uninstaller"; it scans registry for all those odd places that s/ware may have left traces.
