Where did this come from in Internet Explorer when right clicking
FIXED- Subscribe to RSS Feed
- Re: Where did this come from in Internet Explorer ...
21-05-2016 10:43 PM
Re: Where did this come from in Internet Explorer when right clicking
22-05-2016 10:29 AM
Will have been on some s/ware you installed as one of the options; I always refuse them.
My context IE11 menu as attached.
22-05-2016 4:00 PM
Try running Malwarebytes, get rid of them unless you, and it sounds like you didn't, DLed them deliberately
22-05-2016 4:54 PM - edited 22-05-2016 4:55 PM
22-05-2016 5:12 PM - edited 22-05-2016 5:14 PM
I have sorted it
It would appear that this is something added by ieSpell (and possibly others) which I uninstalled a long time ago
To get rid of them I actually had to edit the registry where they were under menuext
Just to add - although I did it myself one of the links by @Casey also showed how to do it
24-05-2016 8:21 AM
I always find it best to remove any s/ware using free prog "Advanced Uninstaller"; it scans registry for all those odd places that s/ware may have left traces.
