Where did this come from in Internet Explorer when right clicking
Fixes: 62
The last couple of items
5 REPLIES 5
Gel
Seasoned Pro
Fixes: 16
Re: Where did this come from in Internet Explorer when right clicking
FreddieFlint
Try running Malwarebytes, get rid of them unless you, and it sounds like you didn't, DLed them deliberately
Casey
Fixes: 62
I have sorted it
It would appear that this is something added by ieSpell (and possibly others) which I uninstalled a long time ago
To get rid of them I actually had to edit the registry where they were under menuext
Just to add - although I did it myself one of the links by @Casey also showed how to do it
Gel
Seasoned Pro
Fixes: 16
I always find it best to remove any s/ware using free prog "Advanced Uninstaller"; it scans registry for all those odd places that s/ware may have left traces.
