Where are Plusnet Protect quarantined files?
- Where are Plusnet Protect quarantined files?
25-05-2015 2:29 PM
When Plusnet Protect finds a suspected virus and quarantines the file what does it do with it and where can I find it?
4 REPLIES 4
Re: Where are Plusnet Protect quarantined files?
25-05-2015 2:34 PM
it stores it in the Plusnet systems
If you want to get it you need to reply to the email you received notifying you of the problem email
25-05-2015 2:39 PM
This isn't related to emails but to the locally running version of Plunet Protect from McAfee. I got a dialogue box that said a virus had been found and the file quarantined but can't find anywhere in the application to manage quaratined files.
25-05-2015 2:52 PM
Sorry
This may help http://service.mcafee.com/FAQDocument.aspx?lc=1033&id=TS100843 note that as they are encrypted you can't see them directly
25-05-2015 3:00 PM
Okay, got it. Thanks!
