Where am I?
u123935
Where am I?
Using Windows 7 and just tried to access Swintons website via TopCashBack using Firefox 38.0.1. Swinton site says "Sorry, you are unable to access this site from outside the UK" but here I am at home in Loughborough, which, the last time I looked, was still in the UK. Any ideas? I've checked all Windows Region settings and they are all ok.
3 REPLIES 3
Oldjim
Resting Legend
Fixes: 63
Re: Where am I?
can you post your IP address here http://community.plus.net/forum/index.php/topic,130918.0.html as it is likely to be the same problem
w23
Fixes: 4
Re: Where am I?
Unless you have a fixed IP (unlikely if you have this problem), clicking 'Disconnect' then 'Reconnect' (or equivalent, may vary with different routers) on your router's interface should give you a new IP address, most likely unaffected by this incorrect geolocation (at worst you may need to try a couple of times).
Please do, if possible, post the offending IP address as requested by Oldjim before doing the disconnect/reconnect though.
Call me 'w23'
Fixes: 1,485
Re: Where am I?
mod:note
locked in favour of existing topic.
