When setting up a new router
petlew
The new router installation went smoothly with the wi-fi reporting "connected". But, and there's always a but, it doesn't connect to the internet.
This is a protocol upgrade from .n to .ac, The existing router has been reactivated, and is working fine (if slower than the .ac is predicted to be).
I'm obviously missing something along the installation, having followed the new router "quick start guide", but I can't see what.
Any suggestions please?
I don't think it makes any difference but the old router is a Netgear DGN2200v3, the new one a TP Link 1200 AC, both are ADSL+2 modem routers. So in theory should be apart from the speed change like-for-like, or is that too simplistic?
6 REPLIES 6
Fixes: 394
Re: When setting up a new router
You have configured the new router with your PlusNet username@plusdsl.net and your password haven't you ?
petlew
Oooops!!Embarrassed
Thank you MisterW.
VileReynard
Fixes: 20
I hope the OP realises that ADSL2 can't achieve ac speeds?
An upgrade to fibre would be far more cost effective - especially as Plusnet could be persuaded to give you discounts plus a free rather manky router.
petlew
So are you saying, stay with the older Netgear router on "n", or, install the later TP-Link which is "ac" capable with a USB wi-fi ac adaptor?
I've had the adaptor for rather longer than the router, I can confirm as expected that there is no benefit with it with the n Netgear router.
VileReynard
Fixes: 20
I was saying the wifi connection can't exceed ADSL2 speeds - unless you get rid of the ADSL2. Wink
RPMozley
Fixes: 13
That's only applicable to accessing the internet. If it was local networking only then you would see a difference.
That's RPM to you!!
