Whats up with F/Fox 26.0
TORPC
Some PlusNet webpages including http://www.plus.net/ will not load in F/Fox 26.0 until I hit F5 or the refresh symbol after at least 5 minutes even then that does not always work.
Even some D/loads fail to start D/loading
All other Browsers like
Chrome
Chromium
IE7, 8, 7, 10 and 11
SRWare Iron
Opera
QTweb
have no issue(s)
Also makes no difference which O/S I have tested with
Vista
Win7
XP (YES I know XP)
even Droid 4.2.2
8 REPLIES 8
Oldjim
Fixes: 63
Re: Whats up with F/Fox 26.0
No problems here - try disabling your addons/plugins or via Safe Mode https://support.mozilla.org/en-US/kb/troubleshoot-firefox-issues-using-safe-mode
shutter
Fixes: 64
No problems here... just clicked the linky and it came up as normal... no hesitation ... download speed here is about 5.5Mb
TORPC
Cheers guys
Turns out the click to skype addon was corrupted, now removed and the problems have gone away
Will keep overnight for monitoring purposes Smiley
shalom2010
Using version 29.0a1 Nightly - nice browser
TORPC
have you a link ?Huh
ReedRichards
Seasoned Pro
Fixes: 25
Does anyone anywhere actually use the click-to-Skype add-on?  I bet it's less than 0.1% of those who have allowed Skype to install it.
shalom2010
TORPC
Cheers CMS
I well check it out as soon as I get more time Smiley
Quote from: ReedRichards
I think I tried it 1 or 2 times and the forgot about it
