Whats up with F/Fox 26.0
- Re: Whats up with F/Fox 26.0
25-01-2014 1:21 PM
Some PlusNet webpages including http://www.plus.net/ will not load in F/Fox 26.0 until I hit F5 or the refresh symbol after at least 5 minutes even then that does not always work.
Even some D/loads fail to start D/loading
All other Browsers like
Chrome
Chromium
IE7, 8, 7, 10 and 11
SRWare Iron
Opera
QTweb
have no issue(s)
Also makes no difference which O/S I have tested with
Vista
Win7
XP (YES I know XP)
even Droid 4.2.2
Chrome
Chromium
SRWare Iron
Opera
QTweb
have no issue(s)
Vista
Win7
XP (YES I know XP)
even Droid 4.2.2
8 REPLIES 8
25-01-2014 1:25 PM
No problems here - try disabling your addons/plugins or via Safe Mode https://support.mozilla.org/en-US/kb/troubleshoot-firefox-issues-using-safe-mode
25-01-2014 1:26 PM
No problems here... just clicked the linky and it came up as normal... no hesitation ... download speed here is about 5.5Mb
25-01-2014 2:52 PM
Cheers guys
Turns out the click to skype addon was corrupted, now removed and the problems have gone away
Will keep overnight for monitoring purposes
25-01-2014 4:11 PM
Using version 29.0a1 Nightly - nice browser
25-01-2014 4:24 PM
have you a link ?
26-01-2014 6:49 AM
Does anyone anywhere actually use the click-to-Skype add-on? I bet it's less than 0.1% of those who have allowed Skype to install it.
26-01-2014 7:55 AM
26-01-2014 2:23 PM
Cheers CMS
I well check it out as soon as I get more time
I think I tried it 1 or 2 times and the forgot about it
Quote from: ReedRichards Does anyone anywhere actually use the click-to-Skype add-on?
