What would be the cheapest mobile PAYG sim to use to contact PlusNet fault line
- Re: What would be the cheapest mobile PAYG sim to ...
07-03-2013 9:14 AM
Will be joining PlusNet home phone and broadband by the end of next week from O2
“Not having anything to do with Sky”
My concern as I am retired due to ill health and not having any friends locally and only having a O2 PAYG sim “only for the O2 broadband discount” which had free calls to O2’s broadband fault reporting line. If there was a line fault? What would be the cheapest mobile PAYG sim to use to contact PlusNet?
6 REPLIES 6
Re: What would be the cheapest mobile PAYG sim to use to contact PlusNet fault line
07-03-2013 10:20 AM
If you're taking Plusnet home phone, then all calls made to support should be free from the land line.
07-03-2013 10:29 AM
Thanks for the reply, when I composed the question it made perfect sense in MY mind. What I should have asked if the line was dead no calls possible?
07-03-2013 2:20 PM
Aha, a valid point!
You need to look at a sim that would allow you some sort of inclusive calls to 0345 numbers. They should be charged at local rate (not 'lo-call' rate, which are 0845 numbers etc). They will either come out of any inclusive minutes you have, or should be reasonably cheap.
07-03-2013 2:40 PM
GiffGaff... free calls to Plusnet 0800 432 0200
As are all UK freephone numbers
http://giffgaff.com/index/pricing
Just make one chargeable call / text within every 180 days.
07-03-2013 3:06 PM
Or OVIVO, which for free gives you
150 free mins, 150 free txt and 400mb of data a month , without needing to top up your account
theres a one off £15 for the sim, but that is put on as credit, outside your allowance 8p a min 5p a txt
to offer the free allowance they send ads to your email.
http://ovivomobile.com/
Regards
Mike
Regards
Mike
07-03-2013 5:12 PM
Thanks for the replies; I think I will take up both options GiffGaff and Ovivo. GiffGaff for contacting PlusNet and Ovivo for friends and family should the line go down.
I have spent the last 6 days reading though various threads in the PlusNet forum, trying to familiarise myself with what’s happening. I have to say I am VERY impressed with the input from various PlusNet staff members.
Thanks again
Thanks again
