What's your pc spec?
Moominfish
Just interested to find out what most users are using these days when it comes to pc spec, so I'll kick this one off,
Mine is,
CPU: Intel Core i7 860 @ 2.80 ghz
Motherboard: Gigabyte P55-UD3
Memory: Corsair XMS3 1333 mhz DDR3
Hard Drives: 2x Samsung F3 1TB hdd's
Graphics Card: Nvidia GTX 275 896 meg gfx card
Monitor: Viewsonic 22" VA2226w widescreen monitor
Case: Antec 300
PSU: Enermax Revolution 850 watts
Fixes: 19
Re: What's your pc spec?
Dell Inspiron 1500 laptop  Roll eyes
Fixes: 20
PIII 933 MHz  Shocked, 2x500Gb, 1x320Gb, 1x160Gb Gigait ethernet card, 1.5Gb Ram, on board Intel Graphics (Runs Xubuntu fine, even with Compiz enabled  Cheesy)
Fixes: 247
Which one Roll eyes Wink
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
I believe what is required is the one with the longest list of parts and gadgets
Waldo
AspireOne:/home/waldo# lshw
aspireone
    description: Computer
    product: AOA150
    vendor: Acer
    version: 1
    serial: LUS050A074837133532535
    width: 32 bits
    capabilities: smbios-2.4 dmi-2.4
    configuration: boot=normal uuid=0078D5D4-67E0-D411-8651-001E68E48C06
  *-core
       description: Motherboard
       vendor: Acer
       physical id: 0
       version: Base Board Version
       serial: Base Board Serial Number
       slot: Base Board Chassis Location
     *-firmware
          description: BIOS
          vendor: Acer
          physical id: 0
          version: v0.3309 (10/06/2008)
          capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb
     *-memory
          description: System Memory
          physical id: 14
          slot: System board or motherboard
        *-bank:0
             description: DIMM Synchronous 533 MHz (1.9 ns)
             product: 0x48594D503136345336344350362D59352020
             vendor: 0xAD00000000000000
             physical id: 0
             serial: 0x00000000
             slot: J2
             width: 64 bits
             clock: 533MHz (1.9ns)
        *-bank:1
             physical id: 1
             serial: 0x00005285
             slot: J6H2
             width: 64 bits
     *-cpu
          description: CPU
          product: Intel(R) Atom(TM) CPU N270   @ 1.60GHz
          vendor: Intel Corp.
          physical id: 1c
          bus info: cpu@0
          version: 6.12.2
          serial: 0001-06C2-0000-0000-0000-0000
          slot: CPU
          capacity: 1600MHz
          width: 32 bits
          clock: 533MHz
          capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe constant_tsc arch_perfmon pebs bts pni dtes64 monitor ds_cpl est tm2 ssse3 xtpr pdcm movbe lahf_lm cpufreq
          configuration: id=0
        *-cache:0
             description: L2 cache
             physical id: 1d
             slot: Unknown
             capacity: 512KiB
             capabilities: synchronous internal write-back unified
        *-cache:1
             description: L1 cache
             physical id: 1e
             slot: Unknown
             capacity: 32KiB
             capabilities: synchronous internal write-back instruction
        *-logicalcpu:0
             description: Logical CPU
             physical id: 0.1
             width: 32 bits
             capabilities: logical
        *-logicalcpu:1
             physical id: 0.2
             width: 32 bits
     *-pci
          description: Host bridge
          product: Mobile 945GME Express Memory Controller Hub
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 03
          width: 32 bits
          clock: 33MHz
          configuration: driver=agpgart-intel
        *-display:0 UNCLAIMED
             description: VGA compatible controller
             product: Mobile 945GME Express Integrated Graphics Controller
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 03
             width: 32 bits
             clock: 33MHz
             capabilities: msi pm vga_controller bus_master cap_list
             configuration: latency=0
        *-display:1 UNCLAIMED
             description: Display controller
             product: Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
             physical id: 2.1
             bus info: pci@0000:00:02.1
             version: 03
             width: 32 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
        *-multimedia
             description: Audio device
             product: 82801G (ICH7 Family) High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 02
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi pciexpress bus_master cap_list
             configuration: driver=HDA Intel latency=0 module=snd_hda_intel
        *-pci:0
             description: PCI bridge
             product: 82801G (ICH7 Family) PCI Express Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport-driver
        *-pci:1
             product: 82801G (ICH7 Family) PCI Express Port 2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: 02
             width: 32 bits
             clock: 33MHz
           *-network
                description: Ethernet interface
                product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: eth0
                version: 02
                serial: 00:1e:68:e4:8c:06
                capacity: 100MB/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half latency=0 link=no module=r8169 multicast=yes port=MII speed=10MB/s
        *-pci:2
             product: 82801G (ICH7 Family) PCI Express Port 3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: 02
             width: 32 bits
             clock: 33MHz
           *-network
                description: Wireless interface
                product: AR242x 802.11abg Wireless PCI Express Adapter
                vendor: Atheros Communications Inc.
                physical id: 0
                bus info: pci@0000:03:00.0
                logical name: wmaster0
                version: 01
                serial: 00:23:4d:00:9d:2b
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix bus_master cap_list logical ethernet physical wireless
                configuration: broadcast=yes driver=ath5k ip=192.168.1.104 latency=0 module=ath5k multicast=yes wireless=IEEE 802.11bg
        *-pci:3
             product: 82801G (ICH7 Family) PCI Express Port 4
             physical id: 1c.3
             bus info: pci@0000:00:1c.3
             version: 02
             width: 32 bits
             clock: 33MHz
        *-usb:0
             description: USB Controller
             product: 82801G (ICH7 Family) USB UHCI Controller #1
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: uhci bus_master
             configuration: driver=uhci_hcd latency=0 module=uhci_hcd
           *-usbhost
                product: UHCI Host Controller
                vendor: Linux 2.6.31.6-waldo-aspireone uhci_hcd
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 2.06
                capabilities: usb-1.10
                configuration: driver=hub slots=2 speed=12.0MB/s
        *-usb:1
             product: 82801G (ICH7 Family) USB UHCI Controller #2
             physical id: 1d.1
             bus info: pci@0000:00:1d.1
             version: 02
             width: 32 bits
             clock: 33MHz
           *-usbhost
                physical id: 1
                bus info: usb@3
                logical name: usb3
                version: 2.06
        *-usb:2
             product: 82801G (ICH7 Family) USB UHCI Controller #3
             physical id: 1d.2
             bus info: pci@0000:00:1d.2
             version: 02
             width: 32 bits
             clock: 33MHz
           *-usbhost
                physical id: 1
                bus info: usb@4
                logical name: usb4
                version: 2.06
        *-usb:3
             product: 82801G (ICH7 Family) USB UHCI Controller #4
             physical id: 1d.3
             bus info: pci@0000:00:1d.3
             version: 02
             width: 32 bits
             clock: 33MHz
           *-usbhost
                physical id: 1
                bus info: usb@5
                logical name: usb5
                version: 2.06
        *-usb:4
             product: 82801G (ICH7 Family) USB2 EHCI Controller
             physical id: 1d.7
             bus info: pci@0000:00:1d.7
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci_hcd latency=0 module=ehci_hcd
           *-usbhost
                product: EHCI Host Controller
                vendor: Linux 2.6.31.6-waldo-aspireone ehci_hcd
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 2.06
                capabilities: usb-2.00
                configuration: driver=hub slots=8 speed=480.0MB/s
              *-usb
                   description: Video
                   product: USB 2.0 Camera
                   vendor: Sonix Technology Co., Ltd.
                   physical id: 5
                   bus info: usb@1:5
                   version: 1.00
                   configuration: driver=uvcvideo maxpower=98mA speed=480.0MB/s
        *-pci:4
             product: 82801 Mobile PCI Bridge
             physical id: 1e
             bus info: pci@0000:00:1e.0
             version: e2
             width: 32 bits
             clock: 33MHz
             capabilities: pci subtractive_decode bus_master cap_list
        *-isa
             description: ISA bridge
             product: 82801GBM (ICH7-M) LPC Interface Bridge
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
        *-ide
             description: IDE interface
             product: 82801GBM/GHM (ICH7 Family) SATA IDE Controller
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             logical name: scsi0
             version: 02
             width: 32 bits
             clock: 66MHz
             capabilities: ide pm bus_master cap_list emulated
             configuration: driver=ata_piix latency=0
           *-disk
                description: ATA Disk
                product: ST9120817AS
                vendor: Seagate
                physical id: 0.0.0
                bus info: scsi@0:0.0.0
                logical name: /dev/sda
                version: 3.AA
                serial: 5RE1GTJA
                capabilities: partitioned partitioned:dos
                configuration: ansiversion=5 signature=f5b94050
              *-volume:0
                   description: EXT3 volume
                   vendor: Linux
                   physical id: 1
                   bus info: scsi@0:0.0.0,1
                   logical name: /dev/sda1
                   logical name: /
                   version: 1.0
                   serial: f436a009-d292-46b4-96a0-e9650fc429b4
                   capacity: 18GiB
                   capabilities: primary bootable journaled extended_attributes large_files huge_files recover ext3 ext2 initialized
                   configuration: created=2009-04-27 20:57:37 filesystem=ext3 modified=2010-04-01 00:26:19 mount.fstype=ext3 mount.options=rw,relatime,errors=remount-ro,commit=600,data=writeback mounted=2010-04-01 00:06:11 state=mounted
              *-volume:1
                   description: Linux filesystem partition
                   physical id: 2
                   bus info: scsi@0:0.0.0,2
                   logical name: /dev/sda2
                   serial: 79f33e51-6c9b-488c-9f74-a4afdf844220
                   capacity: 93GiB
                   width: 256 bits
                   capabilities: primary encrypted luks initialized
                   configuration: bits=256 cipher=aes filesystem=luks hash=sha1 mode=cbc-essiv:sha256 version=1
        *-serial
             description: SMBus
             product: 82801G (ICH7 Family) SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 02
             width: 32 bits
             clock: 33MHz
             configuration: driver=i801_smbus latency=0 module=i2c_i801
Fixes: 20
@Waldo you should have used lspci -vv (Much better info there  Cheesy)
Fixes: 247
Quote from: Santiago
ah.
hmmm... does a quad quad core processor, 16GB RAM and 10TB of hard disk count?
scootie
My living room TV setup now about 4 years old
Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2
          Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
      System Model: Inspiron 531
              BIOS: oC)Phoenix - AwardBIOSTeDell System v6.00PG
         Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ (2 CPUs), ~2.3GHz
            Memory: 3582MB RAM
         Page File: 1377MB used, 6015MB available
Card name: ATI Radeon HD 3400 Series
    Manufacturer: ATI Technologies Inc.
       Chip type: ATI display adapter (0x95C5)
        DAC type: Internal DAC(400MHz)
      Display Memory: 2042 MB
Dedicated Memory: 507 MB
   Shared Memory: 1535 MB
    Current Mode: 1024 x 768 (32 bit) (60Hz)
         Monitor: Generic PnP Monitor + sanyo 37inch lcd (currently got cbeebies on   Crazy )
Description: Speakers (Realtek High Definition Audio)
Disk & DVD/CD-ROM Drives
     Drive: C:
Free Space: 82.5 GB (plenty more storage  about the house on other machines)
Total Space: 305.2 GB
File System: NTFS
     Model: WDC WD32 00AAKS-75B3A SCSI Disk Device
     Drive: F:
     Model: TSSTcorp DVD+-RW TS-H653B SCSI CdRom Device
EXTRA'S.
one slice of jam toast in cd drive and one burbon biscuit in the psu fan
Fixes: 19
Looks like this could turn into a "Mine is bigger than yours", thread Tongue
...... anyone for duck feeding? Roll eyes
Fixes: 225
MB: ASUSTek M4N78
CPU: AMD Phenom II X4 940 3GHz
Memory: 4GB DDR2 6400
HDD: 500GB System + 2x80GB+2x300GB internal - 300GB+400GB+2x1TB external
Graphics: Radeon HD 4850 512MB
Case: Unknown
PSU: 750 Watt
Monitor: Iiyama 26" ProLite E2607WS
W7 32bit
Also
Sony FW56E Laptop
Forum Moderator and Customer
VileReynard
Seasoned Pro
Fixes: 11
OK - here goes Cheesy
lspci -vv
Oops - bug alert - it includes things like Cheesy Cheesy
00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
Subsystem: ASUSTeK Computer Inc. Device 815a
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3)
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 3
Region 0: I/O ports at e400
Region 4: I/O ports at 4c00
Region 5: I/O ports at 4c40
Kernel driver in use: nForce2_smbus
Kernel modules: i2c-nforce2
00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2) (prog-if 10)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0 (750ns min, 250ns max)
Interrupt: pin A routed to IRQ 20
Region 0: Memory at d3104000 (32-bit, non-prefetchable)
Kernel driver in use: ohci_hcd
00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3) (prog-if 20)
Interrupt: pin B routed to IRQ 21
Region 0: Memory at feb00000 (32-bit, non-prefetchable)
Kernel driver in use: ehci_hcd
00:04.0 Multimedia audio controller: nVidia Corporation CK804 AC'97 Audio Controller (rev a2)
Subsystem: ASUSTeK Computer Inc. Device 81ae
Latency: 0 (500ns min, 1250ns max)
Interrupt: pin A routed to IRQ 22
Region 0: I/O ports at dc00
Region 1: I/O ports at e000
Region 2: Memory at d3103000 (32-bit, non-prefetchable)
Kernel driver in use: Intel ICH
Kernel modules: snd-intel8x0
00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev f2) (prog-if 8a [Master SecP PriP])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled]
Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled]
Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled]
Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled]
Region 4: I/O ports at f000
Kernel driver in use: pata_amd
00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3) (prog-if 85 [Master SecO PriO])
Interrupt: pin A routed to IRQ 23
Region 0: I/O ports at 09f0
Region 1: I/O ports at 0bf0
Region 2: I/O ports at 0970
Region 3: I/O ports at 0b70
Region 4: I/O ports at d800
Region 5: Memory at d3102000 (32-bit, non-prefetchable)
Kernel driver in use: sata_nv
00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3) (prog-if 85 [Master SecO PriO])
Region 0: I/O ports at 09e0
Region 1: I/O ports at 0be0
Region 2: I/O ports at 0960
Region 3: I/O ports at 0b60
Region 4: I/O ports at c400
Region 5: Memory at d3101000 (32-bit, non-prefetchable)
00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2) (prog-if 01)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0
Bus: primary=00, secondary=05, subordinate=05, sec-latency=128
Memory behind bridge: d3000000-d30fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR+
BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr+ DiscTmrStat- DiscTmrSERREn-
00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3)
Subsystem: ASUSTeK Computer Inc. Device 8141
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx+
Latency: 0 (250ns min, 5000ns max)
Region 0: Memory at d3100000 (32-bit, non-prefetchable)
Region 1: I/O ports at b000
Kernel driver in use: forcedeth
Kernel modules: forcedeth
00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport-driver
Kernel modules: shpchp
00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: d0000000-d2ffffff
Prefetchable memory behind bridge: 00000000c0000000-00000000cfffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
Kernel modules: amd64_edac_mod
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Kernel driver in use: k8temp
Kernel modules: k8temp
01:00.0 VGA compatible controller: nVidia Corporation G71 [GeForce 7300 GS] (rev a1)
Subsystem: Giga-byte Technology Device 342a
Latency: 0
Interrupt: pin A routed to IRQ 18
Region 0: Memory at d0000000 (32-bit, non-prefetchable)
Region 1: Memory at c0000000 (64-bit, prefetchable)
Region 3: Memory at d1000000 (64-bit, non-prefetchable)
[virtual] Expansion ROM at d2000000 [disabled]
Kernel driver in use: nvidia
Kernel modules: nvidia, nvidiafb
05:08.0 Ethernet controller: Atheros Communications Inc. Atheros AR5001X+ Wireless Network Adapter (rev 01)
Subsystem: Netgear Device 5a00
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 168 (2500ns min, 7000ns max), Cache Line Size: 32 bytes
Region 0: Memory at d3000000 (32-bit, non-prefetchable)
Kernel driver in use: ath5k
Kernel modules: ath5k
Fixes: 62
Question to the posters - has this got silly enough to move it into Chit Chat  Roll eyes
VileReynard
Seasoned Pro
Fixes: 11
Actually this is a bug.
See attached file - Windows users may change the .png "extension" to .txt Cheesy
Quote from: adiewoo
ah.hmmm... does a quad quad core processor, 16GB RAM and 10TB of hard disk count?
now you are just bragging
Quote from: shutter
Maybe yours is bigger than mine, but I have more than you  Tongue
