What is this?
- What is this?
What is this?
10-04-2013 6:46 PM
Just nosing around my Dell Inspiron 1545 laptop`s innards using Piriform "Speccy"... and under the heading "Network". I have found the following....
Current TCP Connections
AvastSvc.exe(352)
BecHelperService.exe (528)
Local 127.0.0.1:22913 LISTEN
Followed by some C:\ Program Files which I do recognise....
I suspect the first line AvastSvc.exe is the one that looks up for the updates to Avast Security... BUT the next line BecHelperService.exe I am wondering what that is... ... ... >....
Can anyone shed light on it.....?
If it is OK... then I`ll leave it there...
on the other hand... if it is not OK... advice on how to remove it..... Please...
( Mods..... Not sure if this is actually Harware but that is where I found it ... on my hardware ! )..
AvastSvc.exe(352)
2 REPLIES 2
Re: What is this?
10-04-2013 7:05 PM
This http://www.file.net/process/bechelperservice.exe.html tends to suggest it's something related to A Three 3g dongle.
Do you have one of those configured on the laptop ?
Re: What is this?
10-04-2013 7:32 PM
I do indeed.... So thanks for that.... Will not worry about it any more now, and get a good nights sleep
Now why did I not think of putting it in Google !.....
