What is the Dynamic IP number range at PlusNet
jondear
What IP number range does the PlusNet dynamic IP range cover?
Can anyone say what it is in this form, eg: 87.115.0.0 - 87.115.255.255 ?
Re: What is the Dynamic IP number range at PlusNet
Plusnet have a number of pools, easiest way to check is to look at:
http://www.ripe.net/whois?form_type=simple&full_query_string=&searchtext=PLUSNET-DIAL-ADSL&do_search...
Quote from: PJ
Why do you need to know?
Why do you need to know why he needs to know? Roll eyes
Quote from: God
I thought you already knew everything? Roll eyes
Fixes: 86
Quote from: PJ
he may not need the information at all.
Is it a secret Wink
Because if so it's probably on a CD somewhere  Grin
Customer and Forum Moderator.
jondear
Thanks for the quick replies... a site I use asks for the IP as a "security" measure, and accepts ranges of IP numbers. Are too many to list?
Thanks for the suggestion of a static IP, I didn't know it was a free service. That would be the most "secure" I suppose. Is it easy (and quick) to switch?
Any downside to having a static IP? And how come they're free, I always thought they came at a premium?
jondear
Just had a look at the range of IPs, and can see why no one listed them. Way too many to list. Mine has always started with 87.115. though.
paulby
Takes a couple of seconds!
Go here (you may need to log in), select "Change IP Settings" and follow the instructions.
