What is the Dynamic IP number range at PlusNet
- Re: What is the Dynamic IP number range at PlusNet
18-01-2008 1:52 PM
What IP number range does the PlusNet dynamic IP range cover?
Can anyone say what it is in this form, eg: 87.115.0.0 - 87.115.255.255 ?
7 REPLIES 7
18-01-2008 2:09 PM
Plusnet have a number of pools, easiest way to check is to look at:
http://www.ripe.net/whois?form_type=simple&full_query_string=&searchtext=PLUSNET-DIAL-ADSL&do_search...
18-01-2008 2:16 PM
Quote from: PJ Why do you need to know?
Why do you need to know why he needs to know?
18-01-2008 2:17 PM
Quote from: God Why do you need to know why he needs to know?
I thought you already knew everything?
18-01-2008 3:13 PM
Quote from: PJ he may not need the information at all.
Is it a secret
Because if so it's probably on a CD somewhere
18-01-2008 4:03 PM
Thanks for the quick replies... a site I use asks for the IP as a "security" measure, and accepts ranges of IP numbers. Are too many to list?
Thanks for the suggestion of a static IP, I didn't know it was a free service. That would be the most "secure" I suppose. Is it easy (and quick) to switch?
Any downside to having a static IP? And how come they're free, I always thought they came at a premium?
18-01-2008 4:06 PM
Just had a look at the range of IPs, and can see why no one listed them. Way too many to list. Mine has always started with 87.115. though.
18-01-2008 4:41 PM
Quote Is it easy (and quick) to switch?
Takes a couple of seconds!
Go here (you may need to log in), select "Change IP Settings" and follow the instructions.
