What has happened to the Fax facility
- Re: What has happened to the Fax facility
10-03-2011 3:53 PM
When I signed on with Plus.net I was given a fax number on which I could receive faxes but not send.
Well, it is not working!
What's happened?
Thanks,
Alex
What's happened?
Thanks,
Alex
2 REPLIES 2
10-03-2011 4:27 PM
See this thread http://community.plus.net/forum/index.php/topic,93680.0.html
10-03-2011 4:34 PM
It looks like it's been removed due to not having been used in the past 3 months, so the number has been reclaimed - looking at your tickets we emailed you on the 2nd to advise what was happening there, if you don't have the email you can see the contents in your tickets at http://contactus.plus.net - the reference is SN105321583
Hope that helps,
Hope that helps,
