What happens after VoIP
Hi Guys,
I am being plastered with VoIP offers and advertisements, so I am wondering how will I keep my connection to Internet once the land lines become defunct?  Any thoughts would be most welcome, even though I am not tempted at the moment.
Best regards,
Alex
30 REPLIES 30
Aspiring Hero
Fixes: 49
Re: What happens after VoIP
FTTP seems the obvious answer here.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Seasoned Pro
Fixes: 11
@Alex_Hamilton
You require a land line for ADSL - whether or not you use the phone.
Fixes: 394
Moderator's Note(s)
Thread moved from ADSL Broadband to Tech Help.
Forum Moderator and Customer
Fixes: 871
I think it’s definitely worth noting that if you port your landline telephone number to VoIP, unless you have FTTP, your broadband connection will cease as well as the phone line and account will ultimately close automatically.
Seasoned Champion
Fixes: 18
VOIP would be useless if you had a power cut - but a landline (connected to a non-digital phone) would be fine.
I wouldn't rely on a mobile for a wide area blackout either.
Sometimes you need to call the emergency services - possibly because of the cause of blackout...
Fixes: 120
Seasoned Champion
Fixes: 18
Have they finished providing internet capability to every dwelling in the land yet?
I can't see that there is any saving in cost for BT - they still have to provide a piece of wire or fibre to each house.
Is this idea from the same source as "smart meters"?
Thank you for the information Baldrick1 and the others. I know that ADSL will not work without a land line and my question was "what are the alternatives and what is Plusnet going to provide instead" and how soon.  2025 looks far away, but my fear is that the land lines will be discontinued as more people switch to VoIP.  I take it that as far as Internet service is concerned, going over to Fibre will work after the land lines are cut.  As for calling emergency services during power cuts, surely mobile networks will continue to work.
Thanks again,
Alex
Fixes: 871
Hi Alex.
Addressing your question to us, I’m afraid we’ve no news to share regarding any new products we may or may not have in the pipeline, but we’ve no plans I’m aware of to discontinue your landline phone.
Fixes: 120
My guess is that due to the very low bandwidth required for voice it's not a problem. From memory Skype worked back in the dial up days, though I could be wrong.
First there's all the hardware in the exchanges that will no longer need to be maintained. Then as I understand how fibre works the street cabinets are connected by fibre back to a head end, which might not be located in the local exchange. Maybe this will make many exchanges redundant, These could then be turned into a nice little earner for BT by flogging them off.
I'm sure that it won't happen unless BT can make money out of it. I suspect that it will hit the same sort of issues as the proposed switch off of FM transmitters.
Seasoned Champion
Fixes: 18
Does any country (no matter how backward) not currently have a landline network?
Its a great idea for non-internet users - instead of just paying BT to use a phone, they pay BT + ISP + Voip provider. Even if they only make occasional calls.
Is there a Voip standard, in the same way as their is a Telephone standard?
Non-standard Skype is plagued by dropouts and poor sound quality, so would need replacing.
@VileReynard, VoIP is a protocol if that is what you are meaning.
Fixes: 120
Am I missing something? As I see it, the current system transfers analogue voice and routing (number being called) data to the exchange, where it's converted to digital data that presumably includes the routing data. From here on it's all digital. Why not do the analogue to digital conversion at the consumers phone and go digital all the way? I'm sure it's not quite this simple but why would this require an ISP and VOIP provider in the loop?
Fixes: 35
@Baldrick1
@Baldrick1 wrote:
@VileReynard
Are you aware that the plan is to put us all on IP phones by 2025? https://www.techradar.com/uk/news/bts-plans-to-switch-off-analogue-phone-network-gather-momentum
Yeah, alright..... and do you remember,... we would all be working in "paperless offices".... and using our own flying cars to get to and from... and ... oh so many other projects... wasn`t there something about a "cashless society" too  ? ? ?  Smart meter  ?  No chance.. I am just as smart, and I can read a meter too ! ! !...
