What format should I use, please?
FIXED- Subscribe to RSS Feed
- What format should I use, please?
- « Previous
- 1
- 2
- Next »
Re: What format should I use, please?
11-09-2017 1:54 PM - edited 11-09-2017 1:55 PM
You can make the video frame rate as fixed or variable.
I use the default 160kbps for the audio rate on my TV because audio typically uses no more than 8% of the AV file size.
11-09-2017 3:57 PM
I forget what default options are set in Any Video Converter (I always setup a manual config with that program).
Options to look out for are in this order (best to worst):
Video codec
MPEG4, XviD, MPEG2
Audio codec
MP3, MPEG2 (to be matched with video MPEG2)
File formats to use are:
.mpg - for MPEG4/2
.avi - for XviD
The MediaInfo details suggest that video is already in MPEG4 so could be just copied through but some low end tech won't play it as they only support 1 ref-frame (yours has 2). As for audio AAC does not look to be supported by your TV, so that definitely needs to be converted (correct term is "transcoded").
11-09-2017 5:37 PM
I use handbrake to give a container format of MP4,
A video format of MPEG4, codec avc1, 4 ref frames, bit rate of 2,000kbps
Audio format of AAC
Subtitles of SRT
Roughly 1GByte per hour.
11-09-2017 6:13 PM
Anyway, those settings you've mentioned won't play on @shutter's television, it's not supported.
11-09-2017 6:23 PM
@RPMozley & @VileReynard thanks for your input... I am sure it will be useful to someone else who reads this thread... however... my reply 15
Edited at the end, shows a really simple and effective solution to my problem... I just drag & drop up to 10 files on to the "Video Converter" part of the suite of "ATubeCatcher"... set the output file , and the output destination... then click on "convert"... job done... ( almost )... I then copy the folder/files to the USB stick...
stick that in the USB slot... chose "source" USB.. and go from there... it`t so simple, no bothering with containing thingys or bit rates ....
- « Previous
- 1
- 2
- Next »
