What do I need to make my laptop connect to wireless router
- What do I need to make my laptop connect to wirele...
Re: What do I need to make my laptop connect to wireless router
31-12-2008 8:26 PM
01-01-2009 10:48 AM
(I had a quick look on eBay myself but didn't spot anything)
01-01-2009 3:56 PM
01-01-2009 8:36 PM
20-01-2009 12:23 PM
Back again!
I have a card - a netgear which my brother has given me. He set it up yesterday at his house and all worked ok but now I am home and nothing doing. Do I need to do something to the PC directly connected to the router? Using the Netgear software and it finds the network but no connection. Is is to do with IP address? pls help
20-01-2009 12:48 PM
No you don't need to do anything to the PC and the router should be issuing IP addresses so that should not be the problem....
assuming that everything is set up for DHCP.
20-01-2009 1:03 PM
Quote from: Strat No you don't need to do anything to the PC and the router should be issuing IP addresses so that should not be the problem....
Even if the netgear was set to a different IP it would still connect to the network, it just wouldn't be able to access anything as it would be on a different subnet. It sounds like you need to configure the security as Strat has said, make sure and use WPA-PSK / WPA2-PSK as WEP is as good as useless for security.
20-01-2009 1:09 PM
20-01-2009 1:47 PM
First the netgear
Here are the settings
Network type - Access Point (Infrastructure)
Security - It can be WPA-2-PSK(AES) or WPA-2-PSK(TKIP)
The password is the same I have for Plusnet
Then when I apply the settings the signal lights come on but then eventually I see the IP address but the message come up that the connection has failed or is limited.
If is it security at present I cannot find where to change the settings on the Thomson router
20-01-2009 1:59 PM
You should be able to see all networks in your locality (although not connect to them).
Can you see yours?
What signal strength do you see (should be shown as a number of green bars)?
If necessary, try moving your laptop closer to the router.
20-01-2009 2:12 PM
How do I see the network? Do you mean from the PC in the control panel?
The laptop is v v close to the router! and we are looking at the Netgear window indicates strength is good but once the IP address is shown the message from the Task bar is that there is limited or no connectivity.
20-01-2009 2:17 PM
20-01-2009 2:24 PM
Most of all myself!! I have a new thomson router which works fine, I used to plug the laptop into the router to connect to internet but I want to use it elsewhere in the house so I have been given a Netgear card for it. My brother put it in and it worked fine with his network so card is OK. He downloaded the software. So now I have come home and want it to work here but it does not!
I think there maybe something with the suggestion it is due to security settings but I dont know how to do this with the router.
Bev
Thanks to all so far
20-01-2009 3:07 PM
The limited / no connectivity is because you need to configure your security.
Your laptop sees the router - but needs information (passwords) to connect to it.
If you refer to the Thomson "instructions", you should see a password which is the same for WEP or WPA security.
It is a combination of digits 0-9 and letters A-F.
It is unique to your router.
20-01-2009 3:19 PM
Quote If you refer to the Thomson "instructions", you should see a password which is the same for WEP or WPA security.
It should be on a sticker on the underside of the router!
Aslo, if you're using the Thomson with its default SSID then the network you are trying to connect to should also be on the sticker underneath (it'll either be Thomsonxxxxx or PlusnetWireless depending on which version of firmware you've got).
To connect (assuming you're running Xp) you need to right click on the small TV screen in the system tray and select "Show available networks". You then need to select your nework and click "Connect". You'll then be prompted to enter the password (the one printed on the bottom of the router). You should now connect all being well!
