What are the risks with default keyring?
- Re: What are the risks with default keyring?
16-10-2012 12:11 PM
Just wondering, put evolution back on as oppose to Thunderbird. When my missus logs into her email account it asks for the default keyring password. I've found a few links to leaving it blank but that comes with risks. Never really seen what the risks are, plus I don't want the password if I create one to be the same as my login password if I can help it.
4 REPLIES 4
17-10-2012 6:40 AM
I've had, in the distant past, my WPA passphrase stored in a 'Default' keyring which resulted in my having to enter the passphrase every time I logged in before I could get a wireless connection to my router (which got very annoying very quickly) - it sounds like you're suffering from something similar (is the password your missus has to type in the password she uses to retrieve mail from a POP3/IMAP server?)
What worked for me (IIRC):
Opened Seahorse, right-click on the Default keyring and choose delete.
Logged out and back in again.
Was prompted to enter my WPA passphrase which this time was stored in a Login keyring
17-10-2012 10:35 AM
Yes mate its so my missus can get her Plusnet email through evolution.
17-10-2012 3:29 PM
Its an iffy one.
IF you log in with a name/password then it should open the default keyring automatically. But if you use auto-login (like most home users) then it will ask for the password as it hasn't been authenticated yet.
18-10-2012 4:04 PM
Ahh ok I see, so perhaps I should just change her account to login with a password and it may not ask again when she opens her email. I know it doesn't ask on my account and I have a passworded login.
