What are the best budget 5Ghz or dualband router(s)
- What are the best budget 5Ghz or dualband router(s...
02-02-2014 7:03 AM
TP-Link
Belkin
Netgear
What are your experiences on the PlusNet ADSL lines that are stable, preferably on a 3db interleaved connection ?? other connections like 6db can also come into the equation
What was your reason for choosing the brand you ended up with ?
What are the pros & cons ?
Please let me explain a little why I am toying with the idea of Dual band or 5Ghz
In my area channels 1 through 12 are badly congested and channel 13 is the only clear channel
I have not long since spoke to Martin @ PN's HQ and he recognised the issue straight away from experience
and
strongly suggested I get a 5Ghz or dual band as the TG582n can not cope under the stress of being overly congested and that is why I have the WiFi drop-outs as discussed at length in the Broadband and routers section.
So I though a little research could not hurt
Re: What are the best budget 5Ghz or dualband router(s)
02-02-2014 9:30 AM
Only used it on 2.4Ghz albeit it is dual band - don't have any 5Ghz devices.
Router is upstairs in back bedroom but main usage is my Roku which is downstairs at front of lounge.
No real stability problems at 3db interleaved.
Channels round here aren't really congested but I've manually set to CH6 as neighbour's HH5 is on Ch 11
02-02-2014 9:35 AM
Another possibility would be to add a 5GHz wi-fi access point to what you already have (the TG582n is, I believe, quite good on the ADSL side, just poor in a congested wi-fi environment), you could even switch off the wi-fi on the TG582n and add both 2.4 and 5Ghz access points (or a dual band concurrent one if you can find such a thing).
04-02-2014 9:03 PM
No idea If they're any good as routers and the interface isn't particularly nice on them but as AP's they work quite well.
I used to have 2 of them configured with the DHCP disabled and then plugged into the network via one of their LAN ports so just acting as dumb switch/ap's used to get ~ 150Mbit/s throughput out of the macbook air on them provided it was in the same room as the AP.
Only reason they're not connected at the moment is I went back to using my UniFI's as I quite like the solution as a whole sadly the ones I have are 2.4ghz only.
08-02-2014 4:16 AM
I nearly forgot about this thread
Not sure what to do as yet, as I still feel more research needs to be done
08-02-2014 11:09 AM
Quote from: TORPC I am toying with the idea of either brands
TP-Link
Belkin
Netgear
More hearsay than experience but Belkin seemed to 'loose the plot' somewhat a few years ago, Netgear have had a few issues too.
What's your budget? Have you considered something like: http://www.amazon.co.uk/Linksys-EA2700-Dual-Band-Router-Gigabit/dp/B007WRYJRO
08-02-2014 11:24 AM
Quote from: 77 What's your budget?
Oops sorry my bad
The budget is for £40 or less as its for the house
08-02-2014 11:52 AM
08-02-2014 10:27 PM
That said, if the OP sticks with the TG582 as the modem/router then he could just add wireless APs to his setup.
08-02-2014 10:34 PM
AFAICS the OP hasn't mentioned ADSL (but I could be wrong / missed something as always).
08-02-2014 10:59 PM
Quote from: 77 AFAICS the OP hasn't mentioned ADSL (but I could be wrong / missed something as always).
Quote from: TORPC [snip]
[snip]
08-02-2014 11:05 PM
and
Quote from: 77 See reply #2
Quote from: 77 but I could be wrong / missed something as always
09-02-2014 9:31 AM
09-02-2014 11:41 AM
09-02-2014 9:09 PM
Quote from: pwatson That said, if the OP sticks with the TG582 as the modem/router then he could just add wireless APs to his setup.
Unless the TG582n has had its long overdue major overhaul, I can not see me sticking with it TBH
As it is ADSL I am really looking for a plugn play replacement, without all the fuss
