Weird permissions query
FIXED- Subscribe to RSS Feed
- Weird permissions query
- « Previous
- 1
- 2
- Next »
Re: Weird permissions query
23-10-2018 9:23 PM
Moderator's note:
Thread moved to 'Tech Help'
26-10-2018 10:17 PM
I've given @bobpullen the 'fix' as his suggestion led me to the solution, but I'm grateful to @picbits for his interest and suggestions - pity you can't give multiple 'This fixed its'
26-10-2018 10:32 PM
No worries - glad you got it all sorted in the end
27-10-2018 8:04 PM
If you ever suspect ublock origin is blocking something, you can use the logger to find out what filter is the culprit and untick it in the settings.
27-10-2018 8:23 PM
@RPMozley It was uBlock Origin 'at fault'. For ease of use, I merely disabled it for that page. I did realise I could have used the logger (later), and will use that if I have problems anywhere else.
- « Previous
- 1
- 2
- Next »
