Webspace
WinfredVaughan
Webspace
I have used up my Plusnet webspace and need some more.  Can anyone recommend a webhost whose webspace is not expensive ?  I do not need a lot normally but at present I am using too much and have been warned to reduce it !
Thanks.
1 REPLY 1
Alex
Fixes: 12
Re: Webspace
Is it just static HTML webpages, or do you need access to an underlying database too (such as MySQL or SQL Server?).
How much (approximately) space do you think you'll need?
EDIT: Forgot to say, do you need PHP support or some other scripting language?
