Webchat on Homehub 4
wncfc
Whenever I try to get through to Plusnet webchat, I get the pop up, enter my details and get No agents available.  I presume that this isn't really the case every time I've tried, so I wonder if there is some setting on the Homehub that needs opening to allow webchat through, although I have successfully connected to other company's webchat.  I've tried on my laptop and my phone with the same result, so I strongly suspect the Homehub is the problem.
1 REPLY 1
chenks76
All Star
Fixes: 12
Re: Webchat on Homehub 4
extremely unlikely to be the hub causing the problem.
two more likely reasons
1) there actually are no agents available when you tried
2) you have a browser issue, be it an ad-blocker of some sorts
