Webalizer problems.
Webalizer problems.
I am running Webalizer on my home websever. Thread about this over in the Linux Forum.
The problem is that I cannot get Webalizer to ignore my own hits from my local network. I have checked it an it is recording hits from www.routerlogin.com which is the name supplied from local hits through my Netgear router. As instructed in the config file I have added:
IgnoreSite www.routerlogin.com
IgnoreURL www.routerlogin.com
I have also tried doing this through Webmin which adds the same lines to the config file anyway. This is not having any effect and Webalizer continues to record my hits. Any ideas?
