Web site connection problem
- Web site connection problem
06-04-2014 3:18 PM
Re: Web site connection problem
06-04-2014 5:59 PM
06-04-2014 7:50 PM
I've heard of someone else with this problem too, She's using windows 8, and that's all I've been told
dick:quote
06-04-2014 10:12 PM
jim:quote
06-04-2014 10:23 PM
I've put this up on another couple of forums. It's early days yet but no one's made any response on either. I'll give it another few days, but I'm reluctantly coming to the conclusion that I'll have to do a reinstall, which is a bit much for a computer only four months old.
06-04-2014 10:27 PM
06-04-2014 10:28 PM
06-04-2014 10:36 PM
1. With a different filter
2. Connected in the test socket
3. Test a Wireless connection (if applicable)
4. Update drivers
5. Try a different Ethernet cable
6. Test alternate Router (if applicable)
What make / model router are you currently using
07-04-2014 4:31 PM
I changed both filters, and that seems to have done the trick.
Ta much for your help, really appreciated
07-04-2014 4:34 PM
Glad your up & running again
