Web Cams
- Re: Web Cams
Web Cams
25-08-2007 4:55 PM
I am unable to view the plusnet office webcams something about
Axis ActiveX Camera Control ,any help welcome Regards E
4 REPLIES 4
Re: Web Cams
25-08-2007 6:54 PM
You need to install the directX camera control. I have uploaded the file you need to my web space for you.
Go to http://www.tutorialsteam.plus.com/axiscameracontrol/AXISCameraServerControl.exe and download the .exe file
Run it on your PC and it will install the necessary software to view the PlusNet webcams.
Moderators note by James_H : Copied file to Tutorials Team webspace, so replaced your link to save bandwidth
Re: Web Cams
26-08-2007 12:23 AM
Hi
I have had trouble with the web cams for ages. However, having read a thread on these fora the other day, I followed a link to a Google search, which led to the Ohio State University of all places (which apparently uses the same software) because having installed it from there, the web cams at Plusnet now work!
So what happened to the really nice fish tank I used to be able to see, from the old cams?
Re: Web Cams
26-08-2007 8:47 AM
Thank you John all working well
Re: Web Cams
31-08-2007 3:27 PM
As has been said previously, Firefox works OK and the best way to view is by using www.kitz.co.uk/adsl/Plusnet_CSCcam1.htm.
