Waterfox update running at maximum of 19kB/s?
Gus
Did a quick wire shark which showed it updating in gold traffic, speed tests show normal speeds at about 5mbit via BT's  Anyone else using Waterfox getting this?  Currently its updating at 9kB/s
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
4 REPLIES 4
Strat
Fixes: 565
Re: Waterfox update running at maximum of 19kB/s?
Mine updated this afternoon...at a snail's pace, occasionally stalling.
nanotm
is it a problem with the download server ?
Strat
Fixes: 565
Just as I was shutting down last night I received a further update notification so 2 updates in the space of a few hours (unusual) quite likely loaded their servers.
Gus
I gave up trying to allow it to update and downloaded the installer, at best the patcher was hitting 9kB/s most of the time
